Clears the DHCP binding entries present on a VLAN.
vlan_name | Specifies the VLAN of the DHCP server. |
N/A.
Use this command to clear the DHCP binding entries present on a VLAN. When an entry is deleted, all its associated entries (such as source IP lockdown, secured ARP, and so on) and their associated ACLs, if any, are also deleted.
The following command clears the DCHP binding entry temporary from the VLAN:
clear ip-security dhcp-snooping entries temporary
This command was first available in ExtremeXOS 12.0.
